wamarlowe
May 12, 2018Aspirant
Wifi Extender Operation
I've just set up the extender (connected to router via ethernet cable) and added three hotspots across my apartment. I notice that the ethernet light only glows on the externder and not on any of the...
DexterJB
May 13, 2018NETGEAR Moderator
Hi wamarlowe,
Welcome to the community!
Please indicate the exact model number/s of the devices involved in your setup for us to provide the correct recommendation.
Dexter
Community Team
- wamarloweMay 14, 2018Aspirant
Dexter,
I have a powerline 1200-100uks* plugged into my router with the additional unit plugged into a wall socket. I have two powerline 1000-100uks* devices plugged into other wall sockets. As mentioned the only device on which the ethernet light glows is the 1200 attached to my router. I don't understand the set-up procedure - as far as I could determine all I had to do was to attach the extender to the router and plugged the other devices into wall sockets around my apartment
I look forward to your advice
thanks
Walter Marlowe
- michaelkenwardMay 17, 2018Guru - Experienced User
Is that the PLP1200? Or the PL1200?
As mentioned the only device on which the ethernet light glows is the 1200 attached to my router.The Ethernet LEDs on the "remote" plugs will not show until you plug something into them.
There is a manual for the PL1200 somewhere at the end of this ink:
>>>> PL1200 | Product | Support | NETGEAR <<<<
See page 5 in the Quick Start guide.
Remember, when adding extra plugs to an existing network, you need to follow this:
>>> Adding a powerline adapter to an existing powerline network <<<
- JamesGLMay 31, 2018NETGEAR Employee Retired
Hi wamarlowe,
We’d greatly appreciate hearing your feedback letting us know if the information michaelkenward provided has helped resolve your issue or if you need further assistance
