wamarlowe
May 12, 2018Aspirant
Wifi Extender Operation
I've just set up the extender (connected to router via ethernet cable) and added three hotspots across my apartment. I notice that the ethernet light only glows on the externder and not on any of the...
wamarlowe
May 14, 2018Aspirant
Dexter,
I have a powerline 1200-100uks* plugged into my router with the additional unit plugged into a wall socket. I have two powerline 1000-100uks* devices plugged into other wall sockets. As mentioned the only device on which the ethernet light glows is the 1200 attached to my router. I don't understand the set-up procedure - as far as I could determine all I had to do was to attach the extender to the router and plugged the other devices into wall sockets around my apartment
I look forward to your advice
thanks
Walter Marlowe
michaelkenward
May 17, 2018Guru - Experienced User
Is that the PLP1200? Or the PL1200?
The Ethernet LEDs on the "remote" plugs will not show until you plug something into them.
There is a manual for the PL1200 somewhere at the end of this ink:
>>>> PL1200 | Product | Support | NETGEAR <<<<
See page 5 in the Quick Start guide.
Remember, when adding extra plugs to an existing network, you need to follow this:
>>> Adding a powerline adapter to an existing powerline network <<<
