nf's avatar
nf
Tutor
Nov 12, 2015
WLAN via Powerline
Hi, I already run some PL adaptors like XAV2501 and need WLAN in a other room - extender does not work so I like to buy a PL WLAN adaptor.
I think the XAVN2001 is not longer available so XWN5001 should be the right one? Will it work with my old ones with lower bitrate?
And, I already have PL up an running so I dont like to buy the kit, only the adaptor for WLAN...is also only this one availbale?
Thanks and have a nice day!
  • They are both HomeplugAV compliant so will work together.  The units will simply just work up to a maximum of their transfer rates.  Netgear have a few wireless adapters (as do other manufacturers).  With the latest firmware i've always found the XWN5001 to be a solid performer
    Hope this helps
