EdwardCunliffe
Nov 23, 2015Aspirant
XAV1301v2 monitoring, Windows 10
Hello, how can I monitor the XAV1301v2 under Windows 10 please, the utility just shows "No device in the network" - I'm pretty sure it used to work OK before I went to Windoze 10 so something is bloc...
JamesGL
Nov 24, 2015NETGEAR Employee Retired
Hi EdwardCunliffe,
Have you tried to uninstall and reinstall the utility?
What is the version of the utility you are using?
Have you tried to use the Desktop genie for powerline management?
- EdwardCunliffeDec 02, 2015Aspirant
Hi James, yes have uninstaled and reinstalled, using Powerline Utility D 3.1.04.
Netgear Genie can see the PC connected to the remote powerline socket, as can the (not Netgear) router but nothing can see the actual powerline devices. I'm certain this worked pre-Windows 10 ...
Ed
- JamesGLDec 02, 2015NETGEAR Employee Retired
Can you provide the screenshot of the Network map in Desktop Genie?
- EdwardCunliffeDec 03, 2015Aspirant
Try again ... Ed-HP is my laptop, George Com(puter) is the one on the remote Powerline adaptor ...
