EdwardCunliffe
Nov 23, 2015Aspirant
XAV1301v2 monitoring, Windows 10
Hello, how can I monitor the XAV1301v2 under Windows 10 please, the utility just shows "No device in the network" - I'm pretty sure it used to work OK before I went to Windoze 10 so something is bloc...
EdwardCunliffe
Dec 02, 2015Aspirant
Hi James, yes have uninstaled and reinstalled, using Powerline Utility D 3.1.04.
Netgear Genie can see the PC connected to the remote powerline socket, as can the (not Netgear) router but nothing can see the actual powerline devices. I'm certain this worked pre-Windows 10 ...
Ed
JamesGL
Dec 02, 2015NETGEAR Employee Retired
Can you provide the screenshot of the Network map in Desktop Genie?
- EdwardCunliffeDec 03, 2015Aspirant
Try again ... Ed-HP is my laptop, George Com(puter) is the one on the remote Powerline adaptor ...
- JamesGLDec 07, 2015NETGEAR Employee Retired
Hi EdwardCunliffe,
Can you provide the Desktop Genie version installed on your computer. Please click on about for the information.
- EdwardCunliffeDec 08, 2015Aspirant
Hi - 2.4.16
