acmollar
Aug 19, 2015Follower
XAV5421 not working
Hi there,
I bought 3 CPL on Aug 17, 2015 and they are not working
We checked the internet box and the laptop is working properly when connected directly to the box.
In parallel, we reset the CPL box and it appears that sometimes they are working ... and sometimes not...................
Is there something we did wrong?
What can we do to have the CPL working ?
Thanks
Did you buy them second-hand (off ebay, for example?)
I would use the Factory Reset button on all units to reset them all to default settings.
I would then be inclined to use the Netgear Genie or Powerline Utility to see if all three are talking to each other (if they are using the same encryption key, which they should do after a factory reset, you should see all three in the list of adapters)
Also check all the usual suspects like faulty cables etc
Link for Powerline Utility:
http://kb.netgear.com/app/answers/detail/a_id/21606/~/powerline-universal-utility-v3.1.0.4
Hope this helps :)
- clithesProdigy
Hope this helps :)
- JulioLemanitouAspirant
Hi,
I've bought a XAVT5421 with 3 CPL and only 2 are talking to each other, even after Factory Reset.
Is the last one not working at all ? Should I retunr the whole package to Aftersale ?
- JamesGLNETGEAR Employee Retired
Hi JulioLemanitou,
Welcome to Community!
Try to connect the adapters just two at a time. Check which device will not work. Try to interchange as well the positions, try to connect each one as the main adapter which is connected to the router.
JamesGL
Community Team
