BAnslow
Jun 22, 2016Aspirant
XAV5602 stop working
Hi, I wonder if someone can help. Just over three years ago, I purchased a pair of Powerline AV500, (XAV5602). I plugged them in, and they worked, right up to a couple of months ago. ...
michaelkenward
Oct 15, 2016Guru - Experienced User
Feynek wrote:...this one did'nt had light =s
No lights = broken.
See page 11 of English User Manual:
XAV5602 | Product | Support | NETGEAR
That shows what each light tells you.
The power light is the important one:
- Solid green. The electrical power is on.
- Blinking green. The adapter is setting up security.
- Amber. The adapter is in power saving mode. If the Ethernet port is inactive for more than ten minutes, the adapter enters power saving mode.
- The adapter does not have electrical power or the LEDs were off using NETGEAR genie.
Remember, there may be an on/off switch on the bottom.
Web you say "power trip", I assume that this means that it you plug something into the power socket that works.
Feynek
Oct 15, 2016Tutor
Damnit, what can i do/ ='(
- michaelkenwardOct 15, 2016Guru - Experienced User
Buy a new one.
- JamesGLOct 19, 2016NETGEAR Employee Retired
Hi Feynek,
If no lights on the 2nd adapter then michaelkenward is correct. You may need to purchase a new one.
JamesGL
Community Team
