gummi's avatar
gummi
XWNB5201 vs XWNB5221
What is the difference between XWNB5201 and XWNB5221?
I noticed a difference in physical dimensions but is there anything else? Trying to decide which one to get.
  • Based on support site: netgear.com
    WiFi Performance
    XWNB5201:
    802.11b/g/n up to 300Mbps
    XWNB5221:
    802.11n up to 300Mbps†
    • Jeannet's avatar
      Jeannet
      Tutor
      I'm sorry - I'm totally ignorant - I can see they're different, but which of these two is better?
      I have a garden studio with a smart TV which receives Wifi fine (e.g. I can get IPlayer), but not Netflix. I'm told Netflix needs a stronger signal.
      The studio is on a different circuit but on the same phase as the house (my electrician tells me). Virgin Media told me to get Netgear XWNB5201 but not which one of these. They did say I should get the one with two antennas - but I can't see which version that is.
      Any advice very much appreciated! With kind regards, Jeannet  :-)
  • I would forget trying to go wireless if you're using powerline.  Just get a powerline to work in an outlet near the television and run a cable--your speeds will be much, much faster this way and netflix will seem like tv.  How do I know?  Because that's what I did.
    We have an FVS318N literally 6 feet away on the other side of a wall.  Just for kicks, I connected a powerline to the FVS318N via a cable and then put another powerline by the tv and connected the tv by cable.  The results?  The internet speed on the television was 6x faster via powerline.  I left the powerlines in place and the television wired.
    • Jeannet's avatar
      Jeannet
      Tutor
      Thanks very much for your response, Samir. I have in the end used a Netgear Wifi Network Extender, and that's working really well. Many thanks for your suggestion, though. All the best, Jeannet :-)
      • SamirD's avatar
        SamirD
        Prodigy
        You're welcome!  If speed is every an issue, now you know exactly what to do. ;)
