itsmesunny
Dec 22, 2015Aspirant
1607: unable to install Installshield scripting in runtime
Hi,
I have done this before and have not had a problem and I do not know what I am doing wrong.
Right now I am using an old dell desktop running windows xp which is the same computer I used earlier ... Windows XP
It is not wireless so I need to hook up the wireless adapter and the wireless router.
It is the 54 Mbps Wireless USB 2.0 Adapter WG111v2.
Hooking up the router is no problem but when I go thru the process for the adapter which is on the screen from the CD - the step by step directions -
I double click on autorun.exe and then the Netgear Start Wizard comes up.
The first thing to do is - Install Driver and Utility.
I double click on that and I am supposed to click on - autorun.exe.
I do and then I get the 1607 error message above.
And that's it. I cannot go any further and I've been looking for answers but am having NO luck.
So - HELP!
You can try downloading and installing the software drivers from their support page for the WG111v2.
- itsmesunnyAspirant
Thanks for the reply.
As it turns out the router works and I am able to connect wirelessly without using the adapter.
Thanks
That's great. Just curious. How were you able to connect wirelessly without using the adapter? You said your computer is not wireless.
