fullyZ
Jun 29, 2013Novice
802.11n symbol with A6200
I was wondering if there is a particular symbol for 802.11ac connection in windows... I can connect up to 866.5Mbps but windows is still showing 802.11n is it normal?
Anonymous
Aug 21, 2013If it makes you feel any better I'm using the Intel AC7260 and nothing I found so far denotes the connection as AC.
INSSIDER shows my max connection at 450, I connect @866.7 all day long.
