SRSmith
Jul 18, 2016Aspirant
A6100 and Windows 10 disconnects frequently
Model A6100 WiFi USB Adapter 802.11ac Dual Band - (got it now?) Software: genie version 1.0.0.12 Driver version: 1030.3.831.2015 Network router is configured for WPA2/AES Connection looks great ...
- Oct 31, 2016
My apologies for not following this thread more closely. This somehow got away from me - but the issue seems to be resolved, and unfortunately I'm not certain what may have fixed it. Windows updates I imagine, but as to which one, I can't tell.
mondenath
Aug 04, 2016Prodigy
See if updating windows 10 to anniversary 1607 build fixes the issue.
tomgt8
Sep 17, 2016Aspirant
I'm having the same issues. Frequent disconnects. I am on the Anniversary version of Win 10 and I changed the power setting as Netgear suggests. Still disconnects. With my wife needing to take some online courses soon that's not going to be acceptable. When it works, it's great but lately not worth the effort. Is Netgear looking into the issue? It's not just a few of us.
- JesperLSep 20, 2016Aspirant
I'm having the same issues with the A6100. After updating to Windows 10 and running the latest drivers 1.0.0.32, it will often disconnect. The Netgear Geenie program will not let med reconnect. Sometimes I can reconnect by using the built-in Windows WIFI selector. Other times I need to reboot, then use the windows selector. No other WIFI devices on my network have this behaviour.
- JamesGLSep 21, 2016NETGEAR Employee Retired
Hi All,
Uninstall the driver and reinstall. When reinstalling, use the standalone driver instead of the driver with Genie.
JamesGL
Community Team
- JamesGLSep 29, 2016NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- tomgt8Oct 31, 2016Aspirant
I've reinstalled as standalone, any more issues and it's in the trash. One thing to think about is that driver is from 2015, it's now close to 2017 and Win 10 has had many changes. Some to the way it handles wifi. Maybe the driver needs tweaking. It worked flawlessly for a few months and then not. Seems like a Win 10 update may have changed things. But that would mean the driver needs an update.
