SRSmith
Jul 18, 2016Aspirant
A6100 and Windows 10 disconnects frequently
Model A6100 WiFi USB Adapter 802.11ac Dual Band - (got it now?) Software: genie version 1.0.0.12 Driver version: 1030.3.831.2015 Network router is configured for WPA2/AES Connection looks great ...
- Oct 31, 2016
My apologies for not following this thread more closely. This somehow got away from me - but the issue seems to be resolved, and unfortunately I'm not certain what may have fixed it. Windows updates I imagine, but as to which one, I can't tell.
JamesGL
Sep 29, 2016NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
SRSmith
Oct 31, 2016Aspirant
- JesperLNov 07, 2016Aspirant
Mine still behaves badly. Every few days, it stops working, and I need to disable the driver, reboot and re-enable the driver in Windows Device management. Its getting highly annoying. Tried several different USB ports, and the network is working fine on other devices.
- tomgt8Nov 07, 2016Aspirant
I finally re-installed mine as a standalone, driver only and so far it seems to be working ok. Whether it's a Windows fix or getting rid of that Genii software I'm not sure. It has only been a couple of days so I could be a little premature in saying it's working. It's reeeaalllyyy frustrating when it's not.
