DumbEngineer
Oct 15, 2024Aspirant
A6100 drivers crash without error during install section
When I open both the adapter and standalone EXEs they both crash once the preparing to install bar reaches 60% every time I open them they then proceed to leave a ghost background process behind in my...
DumbEngineer
Oct 16, 2024Aspirant
Windows 10 Home and what is TM?
michaelkenward
Oct 19, 2024Guru - Experienced User
Do you have the latest drivers for your Windows machine. Not the drivers for the adapter.
What is TM? Who knows. You are the one who used that.
Just another user with time on their hands.
- DumbEngineerOct 21, 2024AspirantI used TM as a abbreviation for Task Manager so I didn’t have to type it 5 times I thought the context I used TM in made it pretty obvious I was referring to task manager but I guess not so obvious and I have the latest windows 10 version available before September 2024
- michaelkenwardOct 21, 2024Guru - Experienced User
DumbEngineer wrote:
I used TM as a abbreviation for Task Manager so I didn’t have to type it 5 timesThere is a well worn way of dealing with that. Read any newspaper article.
You write "Task Manager" first time around and put the TM in brackets afterwards.
Like this: Task Manager (TM). Then you can write TM the next four times.
It avoids confusion and saves time in the long run.
