Stephan_'s avatar
Stephan_
A6100 How to change the "Hosted network supported" from NO to YES
A6100 AC600 WiFi USB Adapter Driver 1030.3.831.2015  OS: Windows 10 Home In PowerShell: "netsh wlan show drivers" "Hosted network supported: No"   <-  I need a YES there how can I change it?
  • Blanca_O's avatar
    Jul 29, 2018
    Hi Stephan_,
    You may want to use this link as reference.
    Blanca
    Community Team
