RoscoePC
May 09, 2016Aspirant
A6100 Installation, Standalone or Genie Version and Windows WLAN AutoConfig
Hello, Thanks for taking the time to read my question. I've searched for this answer and even sent an email to Microsoft, but no answer yet...I cannot find it anywhere. So what I'm wanting t...
RoscoePC
Update to my post:
I should have said if I turn off the Windows WLAN AutoConfig can I still use either the standalone driver or the Genie to access wireless networks on my Windows 8.1 machine? Sorry for the confusion.
- JamesGLMay 18, 2016NETGEAR Employee Retired
Hi RoscoePC,
If you disable the WLAN Autocnofig, your may need to use the Genie version so that the Genie will manage your network settings.
- RoscoePCMay 18, 2016Aspirant
I guess I didn't explain my problem and gave too much information up front and I also notice that some of my wording could be confusing.
So I'll try again, I have Windows 8.1 and I want to use only my NetGear A6100 NIC to handle the wireless in Windows, so can I disable the WLAN service that comes with Windows 8.1 and just use the Genie version of the drivers/firmware I downloaded from netgear.com or do I need both the Windows WLAN service to be turned on plus have the Genie in order to properly use my NetGear NIC?
- RoscoePCMay 19, 2016Aspirant
JamesGL,
thanks for your answer, but you said "may need to use Genie..." which doesn't sound too promising. As a NetGerar forums moderator, I would have thought you would have given a more definite answer.
I can tell already, this is going to turn into some week long ordeal where I never really get an exact and correct answer, so I guess it's my fault for thinking I'd get some use from this forum.
Thanks, I'll just go elsewhere...tired of searching netgear for a simple question to a not so difficult question.
