sli7de
Jul 29, 2016Aspirant
A6100 Loading drivers
I am having issues getting the drivers to load in Windows Server 2016 TP 5.. The drivers I have did load fine in TP3 and TP4 but not TP5. If I run the setup, it says that it can not find the adapter. The device manager does find the adapter. If I try to update drivers it tells me that there is an invalid section in the INF file.
This is what I had to do, Microsoft issue!!
[ Cumulative Update for Windows Server 2016 Technical Preview 5 for x64-based Systems (KB3172982) ]
http://download.windowsupdate.com/d/msdownload/update/software/crup/2016/06/windows10.0-kb3172982-x64_7c13dfeba2f9853fa4ff6e5fb032cee8b344accb.cab
dism /online /add-package /packagepath:D:\windows10.0-kb3172982-x64_7c13dfeba2f9853fa4ff6e5fb032cee8b344accb.cab /LogPath:AddPackage.log /NoRestartDism /online /enable-feature /featurename:WirelessNetworking /All /Source:D:\WinSRV2016\sources\SxS
sc config WlanSvc start=auto
sc start WlanSvcit can connect via settings
- JamesGLNETGEAR Employee Retired
Hi Sli7de,
Please check the system requirements of the adapter under Tech Specs. Your OS may not be supported.
https://www.netgear.com/home/products/networking/wifi-adapters/A6100.aspx#tab-techspecs
JamesGL
Community Team
- sli7deAspirant
