Josh-Stout's avatar
Josh-Stout
A6100 username and password protected wifi
The wifi at my College is protected by a username and password specific to me. After swapping the hard drive on my laptop something went wrong with how I get wifi and I needed a wifi adapter. In the NETGEAR GENIE there is no connect button like there is for the other wifi's. Is there any way that I can connect to this wifi? I have not found any solutions yet. I am running Windows 10 and the driver is fully updated. As seen in below pictures the secure one does not have a connect like the other.
  • michaelkenward's avatar
    michaelkenward
    Doesn't Windows 10 have a connect option that brings up the SSID and password? Mine does.
    It should show you the local networks available. Pick the one you want and bingo.
    • Josh-Stout's avatar
      Josh-Stout
      Since my wifi antenna is fried or something like that it will only run through the genie. When I pull up my wifi from the computer there are no networks available.
        michaelkenward
        Sorry. I don't understand that. If the antenna is fried, how do you expect to connect to the wifi?
        Surely Windows can see networks available to the A6100? It does here.
