Mitchell97
Jan 03, 2016Aspirant
A6100 Wireless Adapter Not Detected By Computer
Hi, I recently bought the A6100 adapter and it is not being detected on my PC. My technical knowledge is limited and all my attempts at fixing this problem have failed :( My operating system is ...
JamesGL
Jan 06, 2016NETGEAR Employee Retired
Hi Mitchell97,
Please try to use the driver version below:
Mitchell97
Jan 07, 2016Aspirant
Hi James,
Thanks for your help! unfortunately it didn't work. The netgear genie tries to detect the adapter, however after 10 minutes it says "adapter could not be detected."
Any more ideas?
Thanks.
- JamesGLJan 12, 2016NETGEAR Employee Retired
Hi Mitchell,
Manually install the driver using the device manager.
