NicholasTu's avatar
NicholasTu
Initiate
Dec 07, 2021
A6150 Constantly Disconnecting Just after Warranty expired
I Have been having this problem about 2 months after i bought it it will just disconnect on me or the speeds will be awfully low. the warrenty expired 3 months ago and since than it has been steadily detiorating into complete unusable garbage as an example i used it to get on here and it took 30 mins of loading and disconnecting and reconnecting to finally get here. the speeds are constantly below 1Mb per second, Any help in getting this sorted would be nice. I have tried EVERY USB Slot on my computer. I think it might be Because it is Overheating but idk.
  • plemans's avatar
    did you recently update windows?
    I've seen a lot of issues on those series where drivers update and then you have concurrent processes running.
    Theres a bunch of posts in the forums or even on youtube for fixes on those series
    https://www.youtube.com/watch?v=ELhMSdv3-Xs
    • NicholasTu's avatar
      NicholasTu
      Initiate
      Seen those vids they do not apply to me beacuse in them they all Turn off and Disable The Netgear RunSw Service, While I Dont Have any services in my pc That Have Netgear in their name. So i cant use those. All I can Find online is for the 7000s and 6210s, none for my specific adapter.
  • michaelkenward's avatar
    michaelkenward
    We know what you think about Netgear and your USB device, but we don't know much about the problem you have with it. Any pattern to the disconnects? All other wifi clients behaving themselves?
    The trouble with these devices is that they rely on Windows, and that can easily get confused.
    Have you looked into the Device Manager in Windows for signs of errors? (Tell it to Show Hidden Devices.)
    While you are in there, look at the Properties of you Wifi Adapter, especially the Power Management tab. See if it helps to turn off Allow the computer to turnoff the device...
    Wifi adapter properties
