viper37
Jan 18, 2015Follower
A6200 adapter stopped working
Hello, First, my system specs: http://pastebin.com/Kdf7871e My problem: As the title says, my adapter stopped working (after roughly 8 months of faithful services). Friday evening, I had a me...
kingw
Oct 06, 2015Aspirant
After scouring the internet for any kind of solution I could find, the following worked for me and seems to have persisted through a reboot.
1. Plug in Netgear A6200
2. Install the driver (I used A6200-V1.0.0.26-1_Software-version/standalone-V1.0.011-win8.1_win10_signed)
3. Open the Registry (regedit), export a copy of HKEY_LOCAL_MACHINE/SYSTEM/CuurentControlSet/Control/Network (File->Export) *This is a backup*
4. Delete the key HKEY_LOCAL_MACHINE/SYSTEM/CuurentControlSet/Control/Network/Config
5. Open Device Manager and Select the Netgear device and uninstall the driver, (I selected delete driver files)
6. Restart the PC
7. Open Device Manager select the Netgear Device (It should be under a different tab now) and update driver software (point it to your prior driver installation)
