FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
Jendrik
Jan 06, 2016Guide
It did not work in my case
JamesGL
Jan 06, 2016NETGEAR Employee Retired
Hi All,
I would like to verify is disconnection happens on 2.4GHz or 5Ghz or is it on both bands.
- FlatoutDudeJan 06, 2016Tutor
It does the same thing on both bands, but i have upgraded to the AC1200 USB 3.0 WIFI Adapter and the issues have ceased and have not appeared since
