FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
JamesGL
Jan 13, 2016NETGEAR Employee Retired
Hi All,
Please try to install the driver while antivirus or firewall are off. Turn on once the driver has been successfully installed.
aim54x
Jan 17, 2016Aspirant
Since I am in the mood for a play I will have a go with the AV/Firewall off and see how it goes
- aim54xJan 17, 2016Aspirant
Just an update...installing the standalone (V1.0.0.11 which was in thee V1.0.0.26-1 package) with the AV/Firewall disabled did not help, I had a cut out just then and will be uninstalling this again.
