FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
Jendrik
Jan 18, 2016Guide
Norhing is working in my case
- jmlow54Jan 24, 2016Guide
Everything listed in this thread has been attempted by me. Without success.
I've also attempted another suggestion to un-check the "Allow Windows to power off" option, w/o success.
Apparently, NetGear can't figure out the cause either for the A6200.
All drivers/OS Updates are current.
Sad that something is important is taking a back-seat to what ever else is going on within NetGear development (The issue has been going on for months now - as evident from other posts.)
