FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
Dan5477
Feb 02, 2016Initiate
Have the A6200, was working fantastic under Win 7. Upgraded to Win 10 pro and get constant disconnects. Tried everything listed in this forum. still get disconnects. I am running an ASUS Crosshair V formula-z mobo. all drivers on board are updated to win 10 from the ASUS site. still get disconnects. tried USB 2.0 and USB 3.0 just to see if there was a difference and there was not. NETGEAR are you going to fix this issue or what? all these people paid for your product and you can't seem to write a decent driver for Windows 10. if anyone fiigures this out, I would greatly appreciate it if you post up your solution.
