FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
rvrby
Feb 13, 2016Tutor
I have the same random disconnect problem, please help.
Using A6200-beta-V1.0.0.35 with win10 Pro 64 bit
Dan5477
Feb 13, 2016Initiate
Sorry to hear you are having the same problem as the rest of us. I had previously contacted Netgear about fixing the issue and they said my 4 month old adapter was no longer qualified for direct support..ha ha ha. Clearly their driver does not work properly with Windows 10 and clearly they have no interest in making it work. I bought the Asus PCE-AC68 last week. I am connected at 1.0gps and I get the fastest download speeds I have ever gotten over wifi (I have a 150/150 connection) I also haven't dropped conenction since I installed it!!! so my netgear A6200 is sitting in a box on the shelf and I will never buy a Netgear product again. best of luck to you, but I highly advise you to move on to a different adapter.
