FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
Retired_Member
Mar 01, 2016
Jendrik wrote:You wont get you money back, I tried that. They want you to buy a new adapter, which in my case would cost even more and I was supposed to either pay the delivery or drive to there store and pick it up myself. I am recommending everyone to stay away from Netgear, I have never experienced a worse customer service than this one right here.
I got lucky and could return my adapter to local store I bought it, they were very friendly and offered me even a new one from another company.
That is lucky.
I am just never going to purchase another Netgear product again, and advise anyone I know never to purchase any Netgear products as well. For a company the size of Netgear, I honestly cannot figure out how it is so difficult for them to get one or two programmers and make a Windows 10 driver that works - oh wait, you are right, they don't care and want you to buy a new network adapter. FORGET THAT!
Istari
Mar 05, 2016Initiate
Dear Netgear,
This is becoming a bit of a joke. Ongoing driver issues since July 2015?
The A6200 was perfectly fine for me until upgrading to windows 10.
Constant device resetting on a vanilla windows 10 installation. Literally the first thing i installed was the netgear drivers, nothing else.
Tried various usb ports and hubs, both 2.0 and 3.0
Please fix this !
Istari
The network interface "NETGEAR A6200 WiFi Adapter" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver detected that its hardware has stopped responding to commands. This network interface has reset 53 time(s) since it was last initialized.
