FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
aim54x
Mar 15, 2016Aspirant
I have both the 26 and 35 drivers another go. Neither seem to have improved. More interesting of the fact that Windows 10 seems to think in connected over 5ghz N not AC even when Genie thinks I'm connected on AC. But then again Genie thinks my other router (non AC) is also connecting via AC. Never noticed this before with my A6200
JamesGL
Mar 16, 2016NETGEAR Employee Retired
Hi aim54x,
Do you have A6210 or A6200? If A6210, please contact support team.
