FlatoutDude's avatar
Sep 11, 2015
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
  • rawnet's avatar
    rawnet
    May 11, 2016
    Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:
    1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;
    2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";
    3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".
    This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
