FlatoutDude
Sep 11, 2015Tutor
A6200 Disconnecting on Windows 10
Im having an issue with the A6200 Wifi Adapter on windows 10, it will work for an intermittent amount of time (usually 5-10min) then completely disconnect, only showing my network when i click on the...
- May 11, 2016Anyone having trouble with Netgear Wireless AC6200 dropping out intermittently after upgrading to Windows 10, here is a possible solution:1. Go to Control Panel\All Control Panel Items\Power Options\Change Plan Settings\Change Advanced Power Settings;2. Expand Wireless Adaptor Settings\Power Saving Mode and make sure it is set to "Maximum Performance";3. Expand USB Settings\USB Selective Suspend Settings and change Setting to "Disabled".This worked for me and YMMV, but I hope this helps avoid the weeks of frustration I've just gone through..
DavidR1234
May 12, 2016Aspirant
I got this for my birthday in January 2016 after reading about it. I have an onboard Atheros Qualcomm AR9485 which is pretty bad with dropouts. When i got the Antennae I was able to connect to the internet with no issues or drop outs. I disabled teh Atheros chip via the change adapter settings.
However in February there was a big update to Win 10 which I can pinpont to teh 6th as i was not able to do any work at all that day because i was not able to able to access the internet and the Atheros wifi chip was reactivated without my persmission. I eventually got to teh route of the problem by reinstalling teh Atheros software and disabling it, I had 2 months pretty well no issues.
Last Friday (6th May) I have not been able to connect to the internet at all using the A6210. Nothing I got the yellow triangle saying no internet or low connection but full bars. I uninstalled teh software adn reinstalled it and still no internet. I reactivated teh Atheros chip again and i was off and running again untill Monday. Since then I have not been able to access the internet via the antennae.
Is it Microsoft who is fu*king us up here? I have used both the netgear driver and the Windows and no rhyme no reason I am still stuck. But methinks that this piece of pap is going out the wind post haste!
Looking at teh feedback history this is not a recent issue. It seems to go back to 2008 on older models.
he sysinfo file shows the following:
Host Name: DAVIDS
OS Name: Microsoft Windows 10 Home
OS Version: 10.0.10586 N/A Build 10586
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: David XXXXXX
Registered Organization: Hewlett-Packard Company
Product ID: 00326-10000-00000-AA303
Original Install Date: 05/02/2016, 12:44:51
System Boot Time: 11/05/2016, 13:12:02
System Manufacturer: Hewlett-Packard
System Model: 700-060ea
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 60 Stepping 3 GenuineIntel ~3401 Mhz
BIOS Version: AMI 80.13, 06/09/2013
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume2
System Locale: en-gb;English (United Kingdom)
Input Locale: en-gb;English (United Kingdom)
Time Zone: (UTC) Dublin, Edinburgh, Lisbon, London
Total Physical Memory: 16,337 MB
Available Physical Memory: 12,386 MB
Virtual Memory: Max Size: 17,361 MB
Virtual Memory: Available: 12,555 MB
Virtual Memory: In Use: 4,806 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\MicrosoftAccount
Hotfix(s): 7 Hotfix(s) Installed.
[01]: KB3135173
[02]: KB3139907
[03]: KB3140741
[04]: KB3140743
[05]: KB3140768
[06]: KB3157993
[07]: KB3147458
Network Card(s): 3 NIC(s) Installed.
[01]: Realtek PCIe GBE Family Controller
Connection Name: Ethernet
Status: Hardware not present
[02]: NETGEAR A6210 WiFi USB3.0 Adapter
Connection Name: WiFi
Status: Media disconnected
[03]: Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter
Connection Name: WiFi DO NOT USE
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: No
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
Windows IP Configuration
Host Name . . . . . . . . . . . . : Davids
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : XX:XX:XX:XX
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Wireless LAN adapter WiFi DO NOT USE:
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Qualcomm Atheros AR9485 802.11b|g|n WiFi Adapter
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : NETGEAR A6210 WiFi USB3.0 Adapter
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
---Software information---
Utility: 1.0.0.34/ Driver: 5.1.22.0
---Site survey information---
SSID Mac Address Security Network Type N WPS Channel
SKY80F87 XX:XX:XX:XX WPA2-PSK Access Point N WPS 11
fa:8f:ca:69:6e:a0 None Access Point N 11
RL_AP-0107c8 XX:XX:XX:XX None Access Point N 64 , 60
SKYF885D XX:XX:XX:XX WPA-PSK/WPA2-PSK Access Point N WPS 11
Pasta_Junction_BeMyGuest2G 08:86:3b:5b:73:87 WPA-PSK/WPA2-PSK Access Point N 6
VM995721-5G XX:XX:XX:XX WPA2-PSK Access Point AC WPS 44 , 48
Pasta_Junction_5G XX:XX:XX:XX WPA-PSK/WPA2-PSK Access Point N WPS 48 , 44
VM841952-5G XX:XX:XX:XX WPA-PSK/WPA2-PSK Access Point N WPS 36 , 40
I have even give the device a static address!!! What is going on? I only got Netgear because of teh brand.
