CptCrunch
Oct 12, 2012Follower
A6200 Experience
Bought the A6200 from Best Buy about 2 weeks ago. I wish I had a great experience normally I speak very highly of Netgear and its products this one is not the case what so ever. I have decent spee...
groves31
Oct 12, 2012Aspirant
Just a thought. Have you checked the usb power management? Open the control panel and then select device manager. Check all the usb root hubs power management tab to see if the computer can power down the hub. If so just uncheck and this will disable the power down.
