CptCrunch
Oct 12, 2012Follower
A6200 Experience
Bought the A6200 from Best Buy about 2 weeks ago. I wish I had a great experience normally I speak very highly of Netgear and its products this one is not the case what so ever. I have decent spee...
BennyTM
Aug 13, 2015Aspirant
Same thing is happening with me once I upgraded...
I only got a problem since a did upgrade.
- DarrenMAug 14, 2015Sr. NETGEAR Moderator
Hello BennyTm and Shalverson
When you upgraded did you uninstall your drivers for the 6200 and reinstall the windows 10 drivers? if not i would suggest removing all the drivers and doing a reinstall of them and when doing this remove the 6200 and wait untill you have all the drivers installed. Also make sure you have your PC drivers up to date for your usb ports. Hope to hear your feedback
DarrenM
