stlblufan
Oct 17, 2012Aspirant
A6200 OSX Support?
I bought the A6200 from MacMall thinking--go figure--that it supports OSX. Turns out I was wrong. Should I return it or is OSX support imminent?
jmizoguchi
Oct 18, 2012Virtuoso
Router does not limits by the o/s so will work fine. Usually any supplement application the issues but genie makes for Mac so there will not issues
