Dugite
Aug 04, 2015Guide
A6200 timing out Windows 10
Hi All, hope I'm not starting a new thread, surely I can't be the only one here with this issue. After upgrading (???) to WX I have found that my WiFi Network icon gets a red X on the top left hand...
Teck1015
Aug 04, 2015Aspirant
I think it's a conjuction of both to be honest. I've attempted to install older drivers and set the process to run in compatibility mode for Windows 7, I successfully connected to the internet for X amount of time and then it times out in the same manner. If it's not data usage it must be a simple communication glitch between the A6200, its drivers, and Windows 10. Tell me, are you using V1.0.0.26 or V1.0.0.35 for your drivers?? V1.0.0.35 (My current driver) aren't labeled as Beta, yet still suffer from disconnecting. Thanks for your input.
