goldnet
Dec 18, 2013Aspirant
A6200 will not connect
Bought A6200 to take advantage of new Airport Extreme router. Although software installed and it sees the networks, it won't connect. Yes the passphrase is correct - works on all our kit. Inbuilt...
Fairytail
Dec 18, 2013Virtuoso
When connecting to the network, what utility did you use?is it the NETGEAR utility or the Windows utility?
