goldnet
Dec 18, 2013Aspirant
A6200 will not connect
Bought A6200 to take advantage of new Airport Extreme router. Although software installed and it sees the networks, it won't connect. Yes the passphrase is correct - works on all our kit. Inbuilt...
goldnet
Dec 20, 2013Aspirant
minions08 wrote: When connecting to the network, what utility did you use?is it the NETGEAR utility or the Windows utility?
Netgear, as I can't use Win Zero configuration with the inbuilt Atheros card
