goldnet
Dec 18, 2013Aspirant
A6200 will not connect
Bought A6200 to take advantage of new Airport Extreme router. Although software installed and it sees the networks, it won't connect. Yes the passphrase is correct - works on all our kit. Inbuilt...
Anonymous
Dec 20, 2013disable the internal wifi in device manager, then delete all netgear drivers and programs related to A6200. Reinstall A6200 using drivers only option that should let windows manage the WIFI
