dhaberle's avatar
dhaberle
Follower
Apr 29, 2016
A6210 adapter will not install drivers
I am trying to install my Netgear A6210 adapter and had the Genie up and running when it asked if I would like to download the latest driver. On completion of the download my genie no longer works, the program is not showing in my programs list so I can not remove it or reinstall it.  The Netgear device is saying there is no driver installed but I have tried downloading from website and reinstalling from CD ( both full setup and stand alone drivers) but get the errors: 1628: failed to complete installation and 1605:This action is only valid for products that are currently installed. I have tried searching for driver via windows as well with no sucess. I am running windows 7.
  • Well, try uninstalling the driver from Add/Remove Programs, then using the CD, re-install, and DON'T update the driver until the bugfix comes out, and, try to do the update with the same card on another PC (Running Vista or XP or 8) and see if it is just a flaw with your PC, or if the software is flawed itself.
    • Mereana05's avatar
      Mereana05
      Hi there - I've had the issue as the person above. I went to Add/Remove programs and uninstalled the adaptor. I've restarted my desktop and gone to reinstall it using the CD. The SAME errors have come up AGAIN! Please help!
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi All,
        If you are getting error message 1605 and 1628 during installation or uninsstalling the device, please contact support and indicate the error message that you are getting.
        JamesGL
        Community Team
