henry_t1
Mar 11, 2016Tutor
A6210 cannot create wireless hotspot!!!
I have created numerous hotspots with other usb adapters. Windows 7 has a built in functionality of allowing wireless network adapters to create hotspots to share internet. This can be done directl...
JamesGL
Mar 01, 2017NETGEAR Employee Retired
Hi all,
I have checked this with the team and this issue is with windows and not with NETGEAR. Please check the link below.
http://www.windowscentral.com/how-turn-your-windows-10-pc-wireless-hotspot
realdead_man
Mar 18, 2017Apprentice
James, that is B.S. Hareware need to conform to windows, not the other way around.
Yes, Windows version 16XX did something to the Wlan stack, but EVERY other card seems to work find. WHY does only Netgear not work?
<Because of the crap drivers, install program, and Genie stink>
Tired of waiting for updates that don't work anyway.
I think TEN (10) MONTHS was a reasonable time to wait for a fix, RIGHT?
Never AGAIN will I BUY NETGEAR.
I purchased an ASUS USB ac53 nano.
(realtek chipset)
WORKS PERFECTLY, all windows versions, all modes!
$40USD
- Amit223Jul 31, 2017Aspirant
I figured how to get the A6210 to work with Windows 10 latest build. It is to install the old driver.
First you will need to temporarily disable driver signature validation. Instructions on doing that can be found http://windowsreport.com/driver-signature-enforcement-windows-10/
Once you have temporarily disabled the driver validation. Then go to install the driver from disk. If you upgraded the old folder should be still there called Windows.old. Go to the driver folder under Windows and you will be able to install the driver.
