Dacruz
Sep 06, 2015Follower
A6210 cant connect to Wpa2
Hello I own a A6210 and can't get it to work with Wpa2. The network security needs to be set to WPA for the adapter to connect. Can someone help?
slow6i
Sep 07, 2015Aspirant
Im having the exact same problem after updating my drivers to the latest version (windows 10 compatible version 5.1.22.0 according to http://puu.sh/k376Z/4fba95bb87.png )
Im running windows 7, with the adapter plugged into a usb 3 port. Its incredibly frustrating because it was working with WPA2 AES with no issues before the latest update. Also, reverting back to the previous driver didnt fix the issue, so the driver must have changed something in windows?
HELP!
- JamesGLSep 10, 2015NETGEAR Employee Retired
Hi All,
Welcome to Community!
Please follow the steps provided on the link below and check if that helps.
JamesGL
Community Team
