A6210Hotspot
May 21, 2016Follower
A6210 Hotspot?
[ Spoiler ] Is it possible to make a hotspot using Win10 and A6210? I`ve bought an A6210 but I can`t create an Acess Point (Hotspot)! I can connect to a Network with my A6210 but i can`t create...
JamesGL
May 25, 2016NETGEAR Employee Retired
Hi A6210Hotspot,
This is not possible for the A6210 or any other wireless adapter for NETGEAR. I would suggest an Extender instead of the adapter.
JamesGL
May 26, 2016NETGEAR Employee Retired
Hi A6210Hotspot,
I am sure of the feature of the adapter. This is only a receiver. You can configure the adapter as an Ad hoc depending on your OS. Check this link.
