CW565
Jan 30, 2017Follower
A6210 Installation Blues
I put in the disk and did the installation but it wouldn't detect my adapter. I decided to try and install the driver from the CD but that gets stuck in an infinite loop asking me to insert the adapt...
RyanRomeroSR
Feb 11, 2017Aspirant
And the answer is a different version of Genie. The one that worked for me came with my Netgear Extender
- VE6CGXFeb 11, 2017Master
Just manually download latest driver and install it. Or don't plug in the adapter until install wizard asks to plug it in.
Just manually download latest driver and install it. Or don't plug in the adapter until install wizard asks to plug it in. Before trying again delete
all the traces of A6210 stuff from your computer(or PC)
- RyanRomeroSRFeb 12, 2017Aspirant
I left everything plugged in, Kept reinstalling : Genie removed and reinstalled itself. However forgot to say I rebooted after install.
This is the particular Item I had previously;
https://www.netgear.com/support/product/WN3000RPv3.aspx?cid=wmt_netgear_organic
Looked a little more into it. Part of it was that it installed another app aswell :
NETGEAR genie Smart Setup
Thats what installed it.
Heres Netgears HIDDEN link....Took FOREVER to find this, hope this helps.
https://www.netgear.com/support/product/Smart%20Wizard%20Utility.aspx?cid=wmt_netgear_organic
