Woozi
Dec 01, 2020Tutor
A6210 isnt firmware is downloading
I have a problem, this the first time i had problem downloading the firmware, When I click download on the a6210 firmware there isnt a file poping up, so i assume it was my pc so, i try download the ...
Dec 01, 2020Guru - Experienced User
I just downloaded it to test it. Worked for me. Did you click the down arrow to the left of the software version?
Woozi
Dec 01, 2020Tutor
Yea but it not showing the file
- plemansDec 01, 2020Guru - Experienced User
I was able to download it and extract it without issues.
Maybe some screen snips of what you're doing can help.
- WooziDec 01, 2020Tutor
Oh I found the solution, I download Firmware in a different browser, Thank you for trying to help me
- schumakuDec 02, 2020Guru - Experienced User
Decent browser builds like e.g. Chrome dislike handling http download links in-line on https sites. Go via the Release Notes link, right click the download URL and "Open in new window" should do the job.
