Woozi
Dec 01, 2020Tutor
A6210 isnt firmware is downloading
I have a problem, this the first time i had problem downloading the firmware, When I click download on the a6210 firmware there isnt a file poping up, so i assume it was my pc so, i try download the ...
Woozi
Dec 01, 2020Tutor
Yea but it not showing the file
Dec 01, 2020Guru - Experienced User
I was able to download it and extract it without issues.
Maybe some screen snips of what you're doing can help.
- WooziDec 01, 2020Tutor
Oh I found the solution, I download Firmware in a different browser, Thank you for trying to help me
- schumakuDec 02, 2020Guru - Experienced User
Decent browser builds like e.g. Chrome dislike handling http download links in-line on https sites. Go via the Release Notes link, right click the download URL and "Open in new window" should do the job.
