godwearinggucci
May 06, 2016Follower
A6210 keeps slowing down a lot until I reconnect it.
I'm running Windows 7 and I'm using the A6210 model adapter to get wifi on my computer since I don't have ethernet in my room. I have the most updated drivers and in preferences, I've unchecked the o...
JamesGL
May 19, 2016NETGEAR Employee Retired
Hi godwearinggucci,
Did you try installing it on a different computer and check the connection speed if the same problem?
