Wallou
Oct 25, 2016Aspirant
A6210 no AC connection , only N
Hi, My A6210 does not connect to my router in AC mode. Only in N. I am on Windows 10 x64. I notice it now because i just got a 1Gb fiber connection and the bandwich is not as it should be. ...
TheEther
Oct 27, 2016Guru
It could be a bug in the Task Manager. Go to Network and Sharing Control Panel and click on the blue link for your Wi-Fi network. IIRC, this will display the connection status and, possibly, the protocol. If you are running Windows 10, then I believe the protocol is also displayed in Settings->Wi-Fi, somewhere.
If you find that the adapter is truly using only N, then go to the driver settings and see if there are any options to use AC.
- WallouNov 18, 2016Aspirant
Hi
Sorry for late reply i have been on holidays for 3 weeks and be back in a few days at home.
Wherever in Windows I look it's a N WiFi connection I have.
I don't recall seeing such a parameter in the driver settings.
I have an Asus RT-AC68U router and as stated above friends get AC connection so the router is fine I think.
I am pretty sure I am in N connection because friends have way better bandwidth speed compared to what i have with my Netgear A6210.
I made tests from the same room in my house and good WiFi signal.
