Casualuser's avatar
Casualuser
Follower
Dec 07, 2016
A6210 "No internet access" no valid IP configuration
Using A6210 wireless adapter to connect to a netgear wireless router. Was working fine, suddenly "No Internet access." When using the Troubleshooting function, computer says it's resetting the wifi adapter, but then finishes with telling me me wifi doesn't have a valid IP configuration. In the network and sharing center, the bars are green and display the name of the correct wireless network, but the access type is: no internet access. I have rebooted the router and I have tried the adapter in several USB ports, the adapter is always recognized but still no internet. Help please!
  • The same thing has happened to me. The problem began yesterday and nothing I have done to fix it has worked.
    Mine drops out frequently, usually Windows 10 shows 'no internet' and then it recycles a minute or two later.  Must've done this every half hour to an hour over the course of this morning.  Only device on my network that has a problem.
