zigbean
Sep 23, 2016Follower
A6210 not detected and cant access 5G
I bought this adapter recently and it installed and worked fine with 5G for a day. After that I had a Windows update which seemed to mess everything up. First, with the adapter plugged in I can only ...
- Apr 03, 2017
Installed latest software version 36
Seems to be working
Genie found the adapter and installed and hooked up 5G
GilM
Sep 24, 2016Aspirant
Hi Zigbean
I am having the same exact problems with my Netgear A6210 Wi-FI USB adapter all good until windows upgrade last week.
I don't see my cable modems 5GHz signal but I can see three other 5GHz SSID's in the wi-fi panel. Very Strange
AND it is not a case of my 5GHz signal from my Netgear 6300 cable being down as I have Fluke specilaist wi-fi testing equipment and the 5GHz is present and my other devices are working on it.
I have tried previous versions of software 32 & 34 no good all of these were downloaded from the Netgear support site.
I tried re-installing my old Netgear USB Wi-Fi Adapter A6200 no good.
Another thing I have noticed is that Netgear Genie will not open as well
I have a standard PC with windows 10 up and running I have not fiddled with the windows environment.
Sorry I can't help but I thought I would let you know that the problem is not isolated.
