zigbean
Sep 23, 2016Follower
A6210 not detected and cant access 5G
I bought this adapter recently and it installed and worked fine with 5G for a day. After that I had a Windows update which seemed to mess everything up. First, with the adapter plugged in I can only ...
- Apr 03, 2017
Installed latest software version 36
Seems to be working
Genie found the adapter and installed and hooked up 5G
GilM
Sep 25, 2016Aspirant
Hi Zigbean
I have solved the problem.
- Open up the Windows 10 Device Manager
- From the list open Network Adapters - Select and right click on 802.11ac Wireless LAN Card
- Select "Update Driver Software" and click
- Select “Let me pick from the list of drivers on my computer”
- Select the Netgear A6210 WiFi USB3.0 Adapter
- Then click next
- The driver will now re-install and you should see the message "Windows has successfully updated your driver".
This is how I solved my problem and I can now see my 5GHz SSID and connect to it
