zigbean
Sep 23, 2016Follower
A6210 not detected and cant access 5G
I bought this adapter recently and it installed and worked fine with 5G for a day. After that I had a Windows update which seemed to mess everything up. First, with the adapter plugged in I can only ...
- Apr 03, 2017
Installed latest software version 36
Seems to be working
Genie found the adapter and installed and hooked up 5G
SEP555
Oct 06, 2016Aspirant
I have just bought this too on the basis i thought it worked with AU. I was wrong. 1511 fine. 1607 it uses this 5.1.22.0. It seems to be the same mediatek driver no matter what adapter you use and ive been unable to delete it and use the previous driver.
My wifes laptop was forced AU today. Internet dead. Luckily immediately reverted back to previous build.
Please netgear MS someone anyone get rid of this damn 5.1.22.0 and mediatek. Its been months now...
Spike_AZ
Oct 08, 2016Aspirant
Started Device Setup Manager in Windows 10 as required by Netgear and the “Not Detected” box does not appear anymore. Still asks me to connect the A6210 again. Software installed. A6210 connects to internet. Connection lasts for a minute or so then disconnects. Uninstalled previous version. Did everything by the book. No Joy.
Downloaded the latest software.
https://www.netgear.com/support/product/A6210.aspx?cid=wmt_netgear_organic#download
- Spike_AZOct 18, 2016Aspirant
Received this answer from Netgear
1. Did you recently update the drivers in your windows 10 computer(windows 10 anniversary update)?
2. If yes, I request you to roll back the update to previous version by contacting your computer vendor or technician.
It seems like the new update on the windows 10 is not compatible with the adapter driver.
The only work around for now is the roll.
We have already notified this issue to the concerned team. I am sorry for the inconvenience caused.
If I get it up and running I will post back HERE
- Spike_AZJan 05, 2017Aspirant
Hello NETGEAR are you listening. It has been almost two months since my post and I am still off line with the 5g. Update 35 is still the latest version available.
- Spike_AZApr 03, 2017Aspirant
Seems to be working
