zigbean
Sep 23, 2016Follower
A6210 not detected and cant access 5G
I bought this adapter recently and it installed and worked fine with 5G for a day. After that I had a Windows update which seemed to mess everything up. First, with the adapter plugged in I can only ...
- Apr 03, 2017
Installed latest software version 36
Seems to be working
Genie found the adapter and installed and hooked up 5G
Spike_AZ
Jan 05, 2017Aspirant
Hello NETGEAR are you listening. It has been almost two months since my post and I am still off line with the 5g. Update 35 is still the latest version available.
Spike_AZ
Apr 03, 2017Aspirant
Seems to be working
